nuvi 8xx (region file only) software version 4.40 du 25 mars
nuvi 8xx (region file only) software version 4.40 du 25 mars Empty nuvi 8xx (region file only) software version 4.40 du 25 mars
Message par Mimi22 Jeu 26 Mar 2009 - 19:40
nuvi 8xx (region file only) software version 4.40 du 25 mars 2009 (bien que le site indique encore la date du 22 janvier de la v4.30) :
Changes made from version 4.30 to 4.40:
Note: Due to new POIs in recent maps, this update enables display of POIs on the map. If you would like to disable them, touch 'Tools -> Settings -> Map -> Down Arrow -> Enabled (adjacent to Show POIs) -> Hide All'.
Corrected POI display behavior in newer maps.
Improved handling of Safety Camera messages.
Corrected the display of the Elevation map in Track Up and North Up map views.
FM transmitter no longer reverts to FM mode after being switched to internal speaker.
Corrected MSN Direct 'Go!' button functionality.
Corrected issue that could result in MSN Direct Flight times to be displayed incorrectly.
Corrected issue that could result in MSN Direct Flight review page error.
MSN Direct Flight Status search selection is now saved in Recently Found list.
Enhanced MSN Direct Flight data so that it is now accessible for all airports regardless of proximity.
Mimi22
6 sat
6 sat
