La mise à jour de MapSource
salut
La mise à jour de MapSource version 6.15.6.0 est dispo!
DRISSI- 2 sat
Re: La mise à jour de MapSource
Elle est là :
Changes made from version 6.15.4 to 6.15.6:
* Fixed an issue with the file save dialog when the file extension field is hidden.
* Fixed an issue where MapSource would crash if the route avoidance dialog would be displayed twice.
* Fixed waypoint category filter issue. Now only waypoints of the selected category will be displayed.
* Fixed waypoint prefixes.
* Fixed an issue where MapSource would crash with certain address searches.
* Fixed memory leaks in the waypoint dialog and map rendering.
* Fixed an issue with saving gpx files when the file path contains Asian characters.
* Fixed some hotkey issues.
* Fixed an issue with searching for certain POIs.
* Fixed an issue with how unlock codes were stored that caused incompatibilities with applications like Training Center.
* Support Web Link Extensions in Brazilian Portuguese.
* Changed waypoint image size to follow the user selected symbol size.
Elle est là :
» Problème de mise à jour MAPSOURCE
» Mapsource version 6.15.4 du 24 février 2009
» Mise à jour Mapsource sur 276 C
» Mapsource mise à jour
» mise a jour G E et mapsource
