Edge Explore 1000 software version 8.10 du 07/06/2017
Message par Monique le Jeu 25 Aoû 2016 - 8:31
Edge Explore 1000 software version : [Vous devez être inscrit et connecté pour voir ce lien]
Tuto pour effectuer la mise à jour via WebUpdater : [Vous devez être inscrit et connecté pour voir ce lien]
Note : Pour le Edge 1000, voir ici : [Vous devez être inscrit et connecté pour voir ce lien]
Change History :
Changes made from version 7.30 to 8.10 (07/06/2017):
Added support for Connect IQ 2.3.1, which includes support for background apps, app trials, and data field trials.
Added support for Varia UT lights, including a new light control page.
Added improvements for ANT+ bike lights. Added new Light Beam Activated and network Light Mode settings to ANT+ Bike Lights sensor settings. You can now configure your lights to turn On with a Timer Start by using the new Light Beam Activated setting and there is also a new Trail Light Mode.
Changes made from version 7.20 to 7.30 (11/04/2017):
Fixed an issue that could keep Garmin Express map downloads from working.
Changes made from version 7.10 to 7.20 (27/03/2017):
Added support for Connect IQ version 2.2.3.
Fixed an issue causing turn guidance to stop working during course navigation.
Fixed heart rate alert setup.
Fixed multiple contact information display for Incident Detection.
Changes made from version 6.00 to 7.10 (04/01/2017):
New feature! Added support for LiveTrack Auto Start.
New feature! Added support for GroupTrack.
Fix Course Creator issues.
Changes made from version 5.00 to 6.00:
New feature! Connect IQ 2.2 Support: Connect IQ Apps, Widgets and Data Fields can now communicate with ANT+ Power Meters and Bike Lights that are already connected to your Edge and can also now take advantage of ANT Burst mode. In addition, Apps and Widgets can take advantage of downloadable content and the new Intents system to create new and innovative experiences.
Fixed an issue with the Turn Guidance Popup where the Map was not centering on the turn.
Improved Incident Detection Alert Page to have proper control flow.
Changes made from version 4.10 to 5.00 (22/09/2016):
Added support for Varia Vision. Pair with this sensor by turning it on and adding it by selecting Settings > Sensors > Add Sensor > Varia Vision. Choose it from your list of sensors to configure its display settings and data screens.
Improved experience with Bontrager lights.
Improved experience with incident detection.
Resolved issue connecting device to computer
Resolved issues related to syncing over WiFi and phone
Changes made from version 4.00 to 4.10 (17/08/2016):
Fixed an issue with syncing Connect IQ settings.
Fixed issue where activities using Connect IQ data fields could be corrupted.
We apologize for the inconvenience, but this update will require you to pair your Edge and phone after the update.
[Mise à jour du post : 10/06/2017]
Fondateur
Fondateur
Re: Edge Explore 1000 software version 8.10 du 07/06/2017
Message par Monique le Mar 8 Nov 2016 - 7:38
version 5.00 disponible
Fondateur
Fondateur
Message par Monique le Ven 27 Jan 2017 - 9:29
version 7.10 disponible
Fondateur
Fondateur
Message par Monique le Ven 21 Avr 2017 - 8:47
version 7.30 disponible
Fondateur
Fondateur
Message par Monique le Sam 10 Juin 2017 - 10:17
version 8.10 disponible
Fondateur
Fondateur
