Edge 520 Plus software version 2.60 du 06/06/2018
Message par Monique le Dim 17 Juin 2018 - 10:03
Edge 520 Plus, software version : ICI
Tuto pour effectuer la mise à jour via WebUpdater : [Vous devez être inscrit et connecté pour voir ce lien]
Note : Pour le Edge 520 "normal", voir [Vous devez être inscrit et connecté pour voir ce lien]
Change History :
Changes made from version 2.50 to 2.60 (06/06/2018):
New Beta Feature: Extended Display Mode. Menu > Settings > Extended Display Mode will allow the Edge device to act as an extended view of a supported Garmin multisport watch’s data fields during a multi-stage activity such as a triathlon. See “Setting Up Extended Display Mode” in the Owner’s Manual for more details.
Smart Notifications: [Android Only] Notifications from additional text-based sources like Google Hangouts will now be shown on device. Responding to these should properly send through the expected application.
Smart Notifications: Notifications that seemed stale or otherwise are not currently being displayed on the phone should no longer be shown on device.
Smart Notifications: Notifications from text and phone sources will be automatically dismissed when no longer relevant.
Turn Guidance: Fixed issue where turn prompts would not be displayed consistently while using 2018.10 maps.
Fixed issue where Virtual Partner time ahead/behind was incorrect when auto-pause is enabled.
Fixed issue where turn prompts would not clear until Varia Radar had no remaining active targets.
Fixed issue where device will not power down properly.
Fixed potential crash when riding a segment against a someone with a very long name.
Fixed issue where pressing the OK button on a prompted route recalculation would not work.
Added eBike icon to status bar page in the list of paired sensors.
Fixed discrepancy between wind displayed on the status par weather preview and the full weather page.
Added additional information to the Copyright Information page.
Fixed incorrect truncation of course points names on the course point list page and on the map.
[Mise à jour du post : 17/06/2018]
Fondateur
Fondateur
