BaseCamp for Mac software version 2.1.1 Beta
BaseCamp for Mac software version 2.1.1 Beta :
Changes made from version 2.0.1 to 2.1.1:
* Added ability for BaseCamp to display any Garmin map. Maps do not need to have Digital Elevation Model (DEM) data to be displayed in BaseCamp now.
* Added support for the data sync capability in the Oregon 550 and Dakota 10 and 20.
* Added ability to drag and drop user data to and from connected devices.
* Fixed issue where garbage characters that were displayed in pop‐up labels in Snow Leopard (10.6).
* Fixed issue where information about found POI or address was not displayed correctly in Snow Leopard.
* Fixed an issue where selecting a waypoint symbol in the Waypoint Dialog could cause a crash.
* Fixed an issue where application could crash during photo track matching.
* Fixed an issue where application could crash when a device is connected or at startup if a device is already connected.
* Fixed an issue where selecting part of a track could cause a crash.
* Fixed issues that could cause a crash while rendering the map in 3‐D.
* Fixed to allow the import of larger GPX files without running out of memory.
* Fixed issue where a dialog incorrectly reminded the user to update his maps was displayed.
» BaseCamp for Mac software version 2.0.0.9 Beta
» BaseCamp for Mac software version 2.0.0.7 Beta
» BaseCamp for Mac software version 3.3.0.1 Beta
» eTrex 20/30 software version 2.61 Beta
» GPSMAP 62/78 software version 3.02 Beta
