nRoute: Quelques FAQ's
Message par Jamas le Jeu 24 Déc 2009 - 0:31
Il m'a semblé utile de poster içi quelques FAQ's relatives à nRoute.
A noter que nRoute vient du français "En Route!"
Ayant un peu la flemme de tout traduire, je poste les FAQ's dans leur langue d'origine. Si quelqu'un a des pbs avec la langue de Shakespeare, m'envoyer un MP.
Question: Will a 3rd party (non-Garmin) GPS work with nRoute?
Est ce qu'un GPS non Garmin marchera avec noute ?
Réponse: No, [note du traducteur: c'est évidement faux, avec GpsGate, on peut émuler un dialogue au format Garmin] nRoute is designed to see only a Garmin GPS. There is proprietary information nRoute needs from the Garmin GPS to unlock maps and function.
Also, the maps that are used in nRoute are locked directly to the one Garmin GPS that came in the package.
Question: What data format must my GPS mode output to work with nRoute?
Quel est le format de données de sortie à paramétrer sur le GPS pour communiquer avec nRoute ?
Réponse: All Garmin® devices must be in Garmin Mode to communicate with the nRoute® program.
Consult the manual [note du traducteur:RTFM ironique ] for your device to determine how to set your interface options.
GPS units that show up as Mass Storage Devices will not work with nRoute.
Question: Why can't I see my map within MapSource or nRoute?
Pourquoi je ne peux pas voir mes cartes installées sous Mapsource dans nRoute ?
Réponse:If you cannot see your detail from your MapSource/nRoute product that is installed on your PC, proceed with the following steps to ensure that the settings in MapSource/nRoute are set correctly:
1. Click View from the Menu Bar
2. Select Switch to Product
3. The Switch to Product will expand to show your installed mapping products
4. Confirm the mapping product you want to view is Checked
If your mapping software already had a check mark next to the name, check the following options:
1. Left-click View from the Main Bar
2. Move your mouse pointer down to where it either says Show GPS Map Detail or Hide GPS Map Detail
3. If it says Show GPS Map Detail, then left-click on it to display the mapping information
If your mapping detail is still not showing, close your MapSource/nRoute program and click the following links and update your MapSource/nRoute software to the current version:
- MapSource: Windows Operating Systems (2000 or later): [Vous devez être inscrit et connecté pour voir ce lien]
- nRoute: Windows Operating Systems (2000 or later): [Vous devez être inscrit et connecté pour voir ce lien]
Question: Why won't my computer detect my Garmin Serial GPS device?
Pourquoi mon PC ne détecte t il pas mon GPS série ?
Réponse: When trying to connect a serial GPS device to a computer the following are common reasons that the computer may not detect the device.
* GPS Setting
* Cable Connection
* Active Processes
* Bad Cable
* Serial Port
- GPS Settings: Make sure that the GPS device is set to Garmin mode (refer to your GPS manual [note du traducteur:RTFM ironique ] for specific instructions)
- Cable Connection: Check to ensure the GPS and the computer are securely connected
- Active Processes: Active processes that can use serial port on the computer can cause communication issues between the GPS and the computer. To determine if an active process on the computer may be causing a communication issue between the GPS device and the computer's serial port:
1. Right-click on the clock at the bottom right corner of the screen and select Task Manager
2. Click on the Processes tab
3. Click on the Image Name to alphabetize the list
4. Look for any active process named Activesync, Hotsync, BBDVMonitor, Besmonitor, Intercept, LVCOMM, Tablet, UPS, WCESComm, WCESMgr, WeatherPak, x10net, ZUNE
5. If you see any of the active processes listed in Step 4, right-click on it and select End Process
6. Click Yes on the Task Manager Warning window to confirm the termination of the process
Note: These processes will start up again every time you reboot the computer.
- Bad Cable: Try another serial interface cable to ensure that the cable is not damaged and blocking some of the data transfer
- Serial Port: As a last resort, try another computer to help narrow down the root cause of the problem between cable and communications port issues.
If detection is not achieved after trying these solutions, there may be a problem with the GPS device itself.
Question: I am getting the error message "Some devices were found; however, none have the necessary capabilities."
J'ai le message d'erreur suivant: "Certaines unités ont été détectées, cependant, aucune n'a les fonctionalités nécessaires"
Réponse: My Garmin GPS unit cannot be seen by the Garmin program.
If you have downloaded the Mapsource program (or WebUpdater, POI Loader, Updater, xImage, Spanner, etc.) and are trying to connect your GPS unit with it, and you are getting an error message.
This error indicates the unit is being seen, but it is not being recognized properly.
* Make sure that your GPS unit is compatible with that specific software program. Some units are not designed to work with certain Garmin applications. Refer to the information page for the software application on our website to determine if your unit is compatible with it.
* Make sure your device is connected to the computer and powered on, then try again.
* If this unit connects to a serial port on the computer make sure that the unit's interface mode is set to Garmin mode (See your owner's manual on how to change this setting).
* The unit will may need to have the most current version of the unit software.
* If you are still getting this error, try to reinstall the USB drivers for this device.
1. Download and run the USB driver installation program from this link: [Vous devez être inscrit et connecté pour voir ce lien]
2. Right-click on My Computer and choose Manage
3. On the left side click on Device Manager
4. If there is anything that looks like "Unknown Device" or "USB Device" with a "?", "!", or a red "X" next to it then right-click on it and choose Uninstall or Remove.
5. On the "Confirm Device Removal" screen click Ok.
6. Click on the Action button at the top left of the Device Manager and choose "Scan for Hardware Changes".
7. The Found New Hardware Wizard will appear. If it asks you if you would like to connect to Microsoft to look for updates say "No, not at this time." and click Next.
8. Choose the option to "Install from a list or specific location." and click Next.
9. Put a check next to "Include this location in a search." and click Browse.
10. Direct it to search in the "C:\Garmin\USB_Drivers\i386" folder.
You should now be able to use your GPS unit with the software program.
Pas de support par mail ou par MP - les questions/réponses se font sur le forum.
[Vous devez être inscrit et connecté pour voir ce lien] -->archives Garmin
Administrateur
Administrateur
Re: nRoute: Quelques FAQ's
Message par Oooops! le Jeu 24 Déc 2009 - 13:35
merci pour cette compilation Jamas [Vous devez être inscrit et connecté pour voir cette image].
À tout hasard, pourrais-tu ajouter dans ton message initial le lien direct vers la page de FAQ de nRoute?
Remarque: ma demande n'a pas pour but de mettre en cause tes infos, mais simplement de jouer la sécurité par redondance: il arrive que le forum, ou que le site de Garmin, soit inaccessible, et même si en général ça ne dure pas longtemps, en vertu de la loi de l'e..erdement maximum [Vous devez être inscrit et connecté pour voir cette image], c'est juste à ces moments-là qu'on en a besoin [Vous devez être inscrit et connecté pour voir cette image].
Et puis accessoirement ça serait mieux du point de vue de la nétiquette [Vous devez être inscrit et connecté pour voir cette image].
Message par Jamas le Lun 28 Déc 2009 - 23:10
Oooops! a écrit:../..pourrais-tu ajouter dans ton message initial le lien direct vers la page de FAQ de nRoute?
Ou ai je bien pu télécharger des Frequently Asked Questions sur un Produit nRoute de chez Garmin ? scratch
sur le site de Magellan, peut être ? study non non chez Tomtom ? Suspect non plus mais c'est bien sur Idea chez Garmin ironique
Quant à la netiquette, accessoirement ou pas, je ne vois pas bien scratch
J Wink m Wink s
PS: il faut taper "nroute" dans la fenêtre 'terme à rechercher' mais ai je besoin de le préciser ?
Administrateur
Administrateur
Message par Oooops! le Mar 29 Déc 2009 - 1:28
merci pour le lien Jamas [Vous devez être inscrit et connecté pour voir cette image]: le site Garmin m'a assez souvent planté, ou du moins fait perdre pas mal de temps, donc je trouve que c'est plus commode si on indique un lien de départ. Quant à la nétiquette, c'est un peu dans le même esprit: quand on extrait pas mal de choses en provenance d'un autre site, l'habitude est de ne pas se contenter d'un nom de site (surtout quand celui-ci est assez énorme) mais de donner au moins une URL de départ précise. Ce que tu viens de faire [Vous devez être inscrit et connecté pour voir cette image].
Remarque: après essai, l'URL peut s'arrêter à [Vous devez être inscrit et connecté pour voir ce lien] [Vous devez être inscrit et connecté pour voir cette image].
Message par Jamas le Mar 22 Juin 2010 - 0:39
Un "user manuel" de nRoute très complet (112 pages mais en anglais Confused [Vous devez être inscrit et connecté pour voir ce lien]
Administrateur
Administrateur
Message par zebulon le Mar 22 Juin 2010 - 8:01
Jamas a écrit:Un "user manuel" de nRoute très complet (112 pages mais en anglais Confused [Vous devez être inscrit et connecté pour voir ce lien]
Wink bonjour,
et comme par hasard quelques instants plus tard l'information était une fois de plus également diffusée sur nature GPS par le pirate Magicbook.
Wink
Nüvi 760 ; Etrex Vista HCX ; Navydrive
Sème du bonheur dans le champ de ton voisin,
tu seras surpris de ce que le vent fera produire au tien.
zebulon
Team Sorcière Monique GPS
Message par Monique le Mar 22 Juin 2010 - 14:24
Il est partout avec plein de pseudos différents celui-là. C'est à croire qu'il n'est plus capable de trouver les infos tout seul. ironique
Cordialement, Monique
...Pensez à sauvegarder le contenu de votre Nuvi ou Zumo en suivant [Vous devez être inscrit et connecté pour voir ce lien]...-...Pensez à consulter [Vous devez être inscrit et connecté pour voir ce lien]
...Pas de support par MP ou par mail, les questions/réponses se font sur le forum.
Administrateur
Administrateur
Message par Monique le Mar 7 Sep 2010 - 7:21
Pour ceux qui souhaiteraient utiliser nRoute avec les dernières versions de City Navigator NT ou avec Topo France, on peut le faire après avoir converti les cartes au format img lu par MapSource 6.13.7. Pour cela, on peut utiliser GMapTool de popej ou MapReverseConverter.
Attention, MapReverseConverter n'est plus en téléchargement sur le site de l'auteur, voir là :
Administrateur
Administrateur
