Update GPS GARMIN 62
+4
popej
Goupil30
8 participants
Page 1 sur 2 1, 2  Suivant
Update GPS GARMIN 62 Empty Update GPS GARMIN 62
Message par Goupil30 Jeu 9 Sep 2010 - 20:03
Changes made from version 2.40 to 2.50: ....... Est ce que c'est plus clair ??
* Added Automatic Shaded Relief option.
* Added display color to track gpx files
* Added import indicator for gpx files
* Added multicaching support
* Added periodic track archiving
* Added track review page improvements
* Improved map selection. Visit [Vous devez être inscrit et connecté pour voir ce lien] for more information.
* Improved keyboard responsiveness
* Fixed issues with inconsistent altimeter readings
* Fixed calendar to display all geocache finds and attempts on the correct day
* Fixed occasional shutdowns
* Fixed paging after logging a geocache
* Fixed shutdown on About Page
* Fixed spot sounding display on certain maps
* Updated map review of tracks and routes. The distance shown is now the distance along the route or track.
Changes made from version 2.30 to 2.40:
* Improved display of position formats on keyboard page.
* Fixed problem with position entry when using Latvian TM position format.
* Removed occasional screen glitch when routes are being calculated.
* Added Spanner interface option to 62 models.
Changes made from version 2.10 to 2.30:
* Added Geocache Filtering
* Added brightness adjustments for BirdsEye imagery
* Improved WAAS performance
* Fixed intermittent issue with two keyboard input bars appearing on spell search
System requirements
1. IBM-compatible PC running Windows XP or later operating system and an available USB port.
Goupil30
Goupil30
Update GPS GARMIN 62 Empty Un de fichiers de la mise à jour est corrompu !!!!!!!!
Message par Goupil30 Jeu 9 Sep 2010 - 20:08
Goupil30
Goupil30
Update GPS GARMIN 62 Empty Re: Update GPS GARMIN 62
Message par Monique Jeu 9 Sep 2010 - 22:18
Je fusionne ce sujet avec celui de la MAJ 2.50.
Message par Monique Jeu 9 Sep 2010 - 22:28
As-tu essayé sur myGarmin ?
Message par Goupil30 Jeu 9 Sep 2010 - 22:59
Goupil30
Goupil30
Message par Jamas Ven 10 Sep 2010 - 0:28
Goupil,
Comme déjà indiqué par Oooops!, autant mettre les infos concernant le détail de la mise à jour en anglais plutôt que mettre ce galimatias sorti d'un traducteur automatique
Update GPS GARMIN 62 Empty maj 2.50
Message par Invité Ven 10 Sep 2010 - 9:09
ce fichier corrompu bloque t il la maj ?
comment as tu détécté cette anomalie ? comment se manifeste t elle ?
Car via webupdater je n'ai pas eu de pb pour faire cette maj, l'appareil avait bien redémarré et j'ai bien la version 2.50 d'indiquée sur le gps
mystère donc ?
olivie
Message par Goupil30 Ven 10 Sep 2010 - 9:41
Exactement le même message ce matin..........
Le Gps est en mode navigation normale pas en mode stockage ?
Goupil30
Goupil30
Message par Goupil30 Ven 10 Sep 2010 - 14:27
Je viens d'essayer une mise à jour à l'aide de mon pc portable, j'ai installé webuptader et ai lancé une demande de maj.
La recherche de périphérique s'est bien passée, identification du gps ok.
j'ai accepté les conditions..... et ai coché la case qui va bien
suivant..........
Idem, même message "un des fichiers de maj est corrompu"
et fin de la mise à jour sans pouvoir passer à la v 2.50
ZUUUUUUT GARMIN REZZZZZZZZUT GARMIN
Goupil30
Goupil30
Message par Invité Ven 10 Sep 2010 - 16:09
As tu essayé l'anglais (dans ton GPS)?
C'était le cas dernièrement sur des Oregon. Problème d'encodage (accents etc..) de caractères... grr
Après une petite rectification, tout est à nouveau rentré dans l'ordre. applaudit
A voir...
Message par Goupil30 Ven 10 Sep 2010 - 17:08
tu veux dire que je met mon gps en anglais et que je fais la maj ??
Goupil30
Goupil30
Message par Goupil30 Ven 10 Sep 2010 - 17:11
Pareil à marcha pa....
Goupil30
Goupil30
Message par Invité Ven 10 Sep 2010 - 17:52
Goupil30 a écrit:tu veux dire que je met mon gps en anglais et que je fais la maj ??
Yes!
C'était le cas sur une mise à jour Oregon bom
Quand les gens réglaient leur GPS en anglais plus de Bug! cheers
Ils ont rectifiés le tir depuis chez GARMIN...
A moins que cela ne soit un problème de versions Windows américain, français...
Il y a quelques différences parait il. Si le programmeur GARMIN n'en a pas tenu compte, cela suffit.
Cela me rappelle un problème au boulot ou le programmeur et ses collègues ont faillit perdre leur latin!
Message par Goupil30 Ven 10 Sep 2010 - 18:45
ok peut être, mais je ne pige pas pquoi un gars est parvenu à faire sa maj !!!
j'ai appelé le gars qui me l'a vendu, il m'a dit que cela venait de chez garmin car j'ai essayé de faire la maj avec un autre pc sous viste et j'ai eu le même buggggggg, RRRRRRRRrrrrrrrrrrrraaaaaaaaaa
Goupil30
Goupil30
Message par Goupil30 Ven 10 Sep 2010 - 18:56
Goupil30 a écrit:ok peut être, mais je ne pige pas pquoi un gars est parvenu à faire sa maj !!!
J'ai le Gps en britche et pareil bug immédiat dès après avoir coché la case qui va bien et cliqué sur suivant; c'est immédiat, rejet.
RRRRRRRRrrrrrrraaaaaaaaaaaa
Goupil30
Goupil30
Message par Goupil30 Ven 10 Sep 2010 - 18:59
Ce qui fout le plus les boules, c'est que Garmin donne un num de téléphone ici [Vous devez être inscrit et connecté pour voir ce lien] et que tu as une charmante voix métallique qui te dit que le numéro n'est pas joignable.
Et demain à la première heure, je pars 1 semaine en rando dans les gorges du Tarn sans asdl...... Re RRRRRRRRRrrrrrrr.........
Goupil30
Goupil30
Message par popej Ven 10 Sep 2010 - 19:31
tu peux essayer de mise à jour manuelle. Voici le fichier:
Renomme-le en GUPDATE.GCD, mets en répertoire \Garmin et redémarre ton GPS.
Utilise des piles neuves lorsque la mise à niveau.
popej
popej
Message par Goupil30 Ven 10 Sep 2010 - 20:21
PopeJ
J'ai fait pil poil ce que tu viens de me proposer (voir dans quel dossier je l'ai mis, c'est bon ???),
redémarré le gps usb raccordé, j'ai sélectionné de ne pas démarrer en stockage et il a démarré complètement sans faire de maj, pas très normal tout ça non ????
A plus voir dossiers du gps ici => [Vous devez être inscrit et connecté pour voir ce lien]
Merci qd même de tenter de me dépanner, mais t'es certain de ton coup, je ne veux pas faire de conne.... je pars 1 semaine dans les gorges du tarn et la maj du gps n'est pas vitale, même en 2.4 il marche pas mal.
Goupil30
Goupil30
Message par popej Ven 10 Sep 2010 - 20:45
Sur ton image le fichier est GUPDATE.GCD.gcd , devrait être GUPDATE.GCD .
Dossier est bon. Je ne suis pas sûr de l'utilisation USB lors de la mise à jour. Cela est impossible sur mon Dakota mais peut-être fonctionne pour 62.
popej
popej
Message par jld63 Ven 10 Sep 2010 - 21:00
bonsoir Goupil30,
En général Popej a la solution...
Je crois que ton fichier s'appelle "GUPDATE.GCD.gcd"... si tu enlèves ".GCD" cela ira peut être mieux.
Sinon, je puis me permettre un avis,...Signale le problème par courriel au support et pars dans les gorges du Tarn avec la 2.4..."Patience et longueur de temps font plus que force et que rage".
JL
jld63
Message par jld63 Ven 10 Sep 2010 - 21:03
Sorry...
mon message est sans objet, Popej est intervenu pendant que j'écrivais...
JL
jld63
Message par Goupil30 Ven 10 Sep 2010 - 22:25
Ohhhhhhhhhhhh LE BOULET GUPDATE.GCD.gcd
Mise à jour, passage à la 2.5 en 20 secondes montre en main
CHAMPION POPEJ, en majuscule SVP
Un grand merci au POLONAIS et à ce forum
Les caches des gorges du Tarn n'ont qu'à bien se tenir.
Biiiiiiiiiiiiiiiiiiiiises à toutes/tous
J'ajoute que la Maj a été effectuée le Gps raccordé en Usb, hors alim par les accus, mais 20 secondes, c'est réel, je ne bluffe pas.
En fait, hors du lien que tu m'as donné, par quel chemin y accèdes tu par le site Garmin ??
Goupil30
Goupil30
Message par Invité Ven 24 Sep 2010 - 13:55
Hello Goupil,
WebUpdater pour la mise à jour 2.6 de ton G62 Very Happy
OK chez moi applaudit
Message par Goupil30 Ven 24 Sep 2010 - 17:32
C'est désespérant, j'ai toujours le message me signalant qu'un des fichiers de la mise à jour était corrompu ......... => [Vous devez être inscrit et connecté pour voir ce lien]
Casse burn.... Garmin et............. je reste poli
Goupil30
Goupil30
Message par Goupil30 Ven 24 Sep 2010 - 17:43
J'ai contourné le blème en opérant comme m'y avait invité Popej le 10 septembre dernier, j'ai DL le fichier [Vous devez être inscrit et connecté pour voir ce lien] l'ai renommé en GUPDATE.GCD, copié dans le dossier GARMIN, arrêté et redémarré le Gps et effectué la MAJ.
Je suis bien passé manuellement à la V 2.60.
En tout cas merci à ce forum pour toutes ses aides et merci à Quiquinou de m'avoir alerté bien que cette MAJ ne soit pas à mes yeux vitale, je préfèrerai la visionneuse qui m'a fait louper des caches la semaine dernière dans les Gges du Tarn.
Byeeeeeeeeeeee
Goupil30
Goupil30
