BaseCamp 3.2.0.1 beta
+3
zeyeti
7 participants
La version BaseCamp 3.2.0.1 beta est disponible sur le forum des développeurs Garmin depuis le 9 mai, ici :
Plein d'ajouts intéressants amha.
Changes :
1. Moved the various property tabs to a separate dialog
2. Added swapping the map and data list UI regions
3. Added activity profiles to allow easier changes between common routing configurations
4. Added geocache search integration with OpenCaching.com
5. Added photo sharing site upload (currently for Picasa)
6. Added track statistics that correspond to the selection in the track points list
7. Added additional statistics to the elevation profile
8. Added display of elevation profile when batch editing routes or tracks
9. Added heart rate and cadence to the track points list and elevation profile
10. Added route to track conversion
11. Added display mode for geocaches
12. Added the "Duplicate" menu item for most user data types
13. Added continuation of route/track drawing when switching between tools
14. Added route avoidance checkboxes to the route options (such as "Avoid U-turns")
15. Added a basic dialog for creating routes
16. Added draw order control for new BirdsEye Imagery that is downloaded
17. Added user selection of application language (the beta is English only, so this doesn't have much of an impact yet)
18. Added option to restore the application to default settings
19. Added tips dialog when entering full screen mode
20. Added a keyboard shortcut to snap the map back to North up
21. Added file import/export support for the TCX file format.
22. Added file export support for tab-delimited and comma-delimited text
23. Added properties and create waypoint commands to the list of POIs that is displayed when hovering on the map
24. Added optional collection of analytics to help us improve the application
25. Added display of the detailed coverage region of card/device based maps
26. Added notification to user when updates are available for devices
27. Added receiving FIT course points and activity data from many fitness devices. These are converted into waypoints and tracks.
28. Changed geotagging photos from a track to add links to those photos in the track
29. Changed to not allow changing the location of geocaches when they are part of a route
30. Changed the divide tool to create a new waypoint or trackpoint at the division point
31. Fixed issue where we didn't always remove all waypoints created as part of a route
Changes :
Re: BaseCamp 3.2.0.1 beta
yeahh, bien vu Monique [Vous devez être inscrit et connecté pour voir cette image] (surtout pour ce que tu as mis en rouge).
Peut-être enfin une bonne raison pour moi de passer à BaseCamp; mais de toutes façon, une fois que les bêtas (à qui ou à quoi que ce terme s'applique [Vous devez être inscrit et connecté pour voir cette image]) auront essuyé les plâtres...
Si on passe à basecamp, comment récupère t'on les cartes présentent dans mapsource ?
zeyeti- 1 sat
Salut zeyzti, une Foix basecamp téléchargé il récupère sans intervention toute les cartes que tu as dans l'encienne version et MapSource si toutefois ils sont dans le dossier garmin .
C'est ce qui c'est passé pour moi.
imamar- 3 sat
Pour info, cette version d'essai n'est qu'en anglais.
Quand vous l'installez, vous mettez une version en plus de BaseCamp qui s'appelera BaseCamp Beta et une application sup Webupdater Beta.
Vous verrez que cette version rajoute beaucoup de fonction comme les fonctions de dénivelé positif et négatif total sur la page de profil, les profiles d'utilisation,...
TeddyGPS- 3 sat
Ce qui veut dire que l'on a deux applications BaseCamp en parallele sur le PC?
Et WebUpdater Quid?
Et WebUpdater Quid?
DAIG- 3 sat
oui mais la version beta est limitée dans le temps , 25/07 pour la version actuelle 3.2.0.2 , ce sont des phases successives pour le temps de le finalisation je supposeDAIG a écrit:Ce qui veut dire que l'on a deux applications BaseCamp en parallele sur le PC?
gaster- 4 sat
» Basecamp 4-2-0-2-Bêta
» BaseCamp mises à jour (depuis la 3.3.3)
» BaseCamp 3.3.0.2 Beta
» BaseCamp for Mac software version 3.3.0.1 Beta
» BaseCamp for Mac software version 2.0.0.7 Beta
