nuvi 865T software version 4.40 du 27 mars
nuvi 865T software version 4.40 :
Changes made from version 4.30 to 4.40:
◦Note: Due to new POIs in recent maps, this update enables display of POIs on the map. If you would like to disable them, touch 'Tools -> Settings -> Map -> Down Arrow -> Enabled (adjacent to Show POIs) -> Hide All'.
◦Corrected POI display behavior in newer maps.
◦Improved handling of Safety Camera messages.
◦Corrected the display of the Elevation map in Track Up and North Up map views.
◦FM transmitter no longer reverts to FM mode after being switched to internal speaker.
◦Corrected MSN Direct 'Go!' button functionality.
◦Corrected issue that could result in MSN Direct Flight times to be displayed incorrectly.
◦Corrected issue that could result in MSN Direct Flight review page error.
◦MSN Direct Flight Status search selection is now saved in Recently Found list.
◦Enhanced MSN Direct Flight data so that it is now accessible for all airports regardless of proximity.
Mimi22- 6 sat
» nuvi 860 software version 4.40 du 27 mars
» nuvi 8xx (region file only) software version 4.40 du 25 mars
» nuvi 2797 (nuvi 27x7 and 27x8) software version 5.40 du 03/10/2016
» Nuvi 2x5W et Nuvi 2x5 (region file only) software version 6.20
» software version 7.10 pour Nuvi 2x5 et Nuvi 2x5W (GCD File - MTK)
