Edge 520 software version 13.20 du 13/08/2020
Edge 520 software version 13.20 du 13/08/2020 Empty Edge 520 software version 13.20 du 13/08/2020
Message par Monique Jeu 25 Aoû 2016 - 8:24
Edge 520 software version : ICI
Tuto pour effectuer la mise à jour via WebUpdater : [Vous devez être inscrit et connecté pour voir ce lien]
Note : Pour le Edge 520 Plus, voir [Vous devez être inscrit et connecté pour voir ce lien]
Change History :
Changes made from version 13.10 to 13.20 (13/08/2020):
Made various device stability improvements
Changes made from version 13.00 to 13.10 (30/05/2020):
Reduced speed dropouts when connected to indoor trainers.
Fixed virtual partner issues caused by the timer being paused.
Fixed a workout naming issue.
Other minor fixes.
Changes made from version 12.90 to 13.00 (05/06/2019):
Updated battery capacity model to better reflect the remaining battery life of older batteries.
Added support for 12-speed shifting sensors.
Fixed data field issues when using a shifting system with no front derailleur.
Made several improvements to the Sensor Details UI for Vector 3 power meters.
Fixed issue causing some Connect IQ apps to not be able to make web requests through the phone connection.
Added filter to eliminate unrealistic power spikes coming from the sensor.
Changes made from version 12.80 to 12.90 (201/11/2018):
Fixes an issue causing custom fonts in Connect IQ apps to not display properly.
Fixes a crash when syncing emergency contact data that has a long email address listed.
Fixes an issue with the Time/Distance Ahead data fields when doing a distance only target.
Changes made from version 12.60 to 12.80 (26/09/2018):
Updated Connect IQ to version 2.4.6.
Improved device responsiveness for Varia Radar connectivity.
Fixed issue causing device to be unable to acquire a GPS signal.
Fixed issue causing heart rate and power zones to be reset when creating a custom activity profile.
Fixed issue causing HR - %Max data field to not work with custom activity profiles.
Made UI improvements to Incident Detection.
Changes made from version 12.50 to 12.60 (25/04/2018):
Updated Connect IQ to version 2.4.4.
Improved power zones UI.
Fixed calibration prompt for SRM power meters.
Improved Bluetooth connection stability when connected to a Varia Radar.
Fixed an issue that could cause a crash when connected to Vector 3 or Varia UT.
Changes made from version 12.40 to 12.50 (12/12/2017):
• Fixed Connect IQ arc drawing.
Changes made from version 12.30 to 12.40 (29/11/2017):
Added Connect IQ 2.4.1 support.
Updated the Indoor Trainer feature to reset resistance to 10% after finishing a power or resistance workout target step as long as it is not followed by another power or resistance target.
Fixed issue causing RTL 500 to not shut down properly at the end of a ride.
Changes made from version 12.20 to 12.30 (10/10/2017):
Fixed configuring Shimano Di2 sensor settings.
Improved the user interface for Vector 3 software updates.
Fixed an issue allowing Connect IQ Apps to disable sensors.
Changes made from version 12.10 to 12.20 (29/08/2017):
Improved the user interface for Shimano Di2 sensors.
Improved the user interface for Vector setup.
Fixed issues with embedded segments in courses.
Fixed an issue that could prevent bike light networks from reforming.
Fixed an issue when attempting to load more than 100 segments.
Fixed an issue causing the device to crash when repeatedly going in and out of Bluetooth range with a phone.
Updated precision of the Grade data field to whole %'s.
Changes made from version 11.10 to 12.10 (08/06/2017):
Added support for Connect IQ 2.3.1, which includes support for background apps, app trials, and data field trials.
Updated navigation instructions to use course points if they are available.
Improved bike light handling for indoor activity profiles.
Changes made from version 11.00 to 11.10 (29/03/2017):
Fixed issue causing elevation to be incorrectly offset.
Fixed minor issues related to Connect IQ.
Changes made from version 10.00 to 11.00:
New Feature! Added support for Shimano Di2 Synchronized Shift. Graphical Gear data fields will now blink, an alert tone will be played, and a message banner will be displayed to indicate a chain ring shift is upcoming. Synchronized Shift mode can be changed and the alert tones can be disabled through the Shimano Di2 sensor settings.
Added improvements for ANT+ bike lights. Added new Light Beam Activated and network Light Mode settings to ANT+ Bike Lights sensor settings. You can now configure your lights to turn On with a Timer Start by using the new Light Beam Activated setting and there is also a new Trail Light Mode.
Added support for Connect IQ version 2.2.3.
Added segment start points to the map.
Fixed power zone settings not being retained.
Fixed compass text in night mode.
Changes made from version 9.10 to 10.00:
New feature! Incident Detection: in the event of an incident, this feature can send your location to your emergency contacts specified on Garmin Connect Mobile.
Improvements to Workout Data Screen.
Improved Grade calculation.
Changes made from version 8.00 to 9.10:
New feature! Connect IQ 2.2 Support: Connect IQ Apps, Widgets and Data Fields can now communicate with ANT+ Power Meters and Bike Lights that are already connected to your Edge and can also now take advantage of ANT Burst mode. In addition, Apps and Widgets can take advantage of downloadable content and the new Intents system to create new and innovative experiences.
Changes made from version 7.20 to 8.00 (20/10/2016):
New feature! Added support for LiveTrack Auto Start.
Added Distance and Time Ahead/Behind as configurable data fields.
Changes made from version 7.10 to 7.20 (07/09/2016):
Fixed several issues and made improvements for Varia Vision.
Fixed several issues and made improvements for Connect IQ.
Made improvements to the software update page.
Added mixed surface ride type.
Changes made from version 7.00 to 7.10 (15/08/2016):
Fixed an issue with syncing Connect IQ settings.
Fixed issue where activities using Connect IQ data fields could be corrupted.
We apologize for the inconvenience, but this update will require you to pair your Edge and phone after the update.
Edge 520 software version 13.20 du 13/08/2020 Empty Re: Edge 520 software version 13.20 du 13/08/2020
Message par Monique Mar 8 Nov 2016 - 7:39
version 8.00 disponible
Message par Monique Ven 21 Avr 2017 - 8:55
version 11.10 disponible
Message par Monique Sam 10 Juin 2017 - 10:09
version 12.10 disponible
Message par Monique Ven 1 Sep 2017 - 12:16
version 12.20 disponible
Message par Monique Jeu 12 Oct 2017 - 7:34
version 12.30 disponible
Message par Monique Sam 2 Déc 2017 - 17:59
version 12.40 disponible
Message par Monique Mer 13 Déc 2017 - 9:24
version 12.50 disponible d'après le forum Garmin US
Message par Monique Mar 12 Juin 2018 - 21:49
(Avec du retard Embarassed ) version 12.60 disponible
Message par Monique Lun 1 Oct 2018 - 10:46
version 12.80 disponible
Message par Monique Sam 12 Jan 2019 - 16:50
version 12.90 disponible
Message par Monique Sam 8 Juin 2019 - 8:30
version 13.00 disponible
Message par Monique Mar 2 Juin 2020 - 11:45
version 13.10 disponible
Message par Monique Ven 14 Aoû 2020 - 13:59
version 13.20 disponible
