Edge 1030 software version 7.50 du 13/06/2019
Page 1 sur 2 1, 2  Suivant
Edge 1030 software version 7.50 du 13/06/2019 Empty Edge 1030 software version 7.50 du 13/06/2019
Message par Monique le Ven 13 Oct 2017 - 17:49
Edge 1030 software version : ICI
Tuto pour effectuer la mise à jour via WebUpdater : [Vous devez être inscrit et connecté pour voir ce lien]
Change History :
Changes made from version 7.40 to 7.50 (13/06/2019):
Added the option to choose the radar alert tone.
Improved wireless performance for the ANT STEPS profile.
Fixed issue with Shimano E8000 Di2 gear display.
Added eBike activity logging.
Fixed issues with the cycling dynamics page.
Fixed issue where two locations with long, similar names would cause the device to crash.
Fixed issues with loading very long courses.
Changes made from version 7.30 to 7.40 (30/05/2019):
Miscellaneous bug fixes
Changes made from version 7.20 to 7.30 (03/04/2019):
Fixed a crash that could occur when riding with a cadence sensor.
Changes made from version 7.00 to 7.20 (13/03/2019):
Improved connection to the Edge Remote.
Fixed issue causing Connect IQ MapView to not handle inputs.
Fixed incorrect navigation audio tones from the 7.00 update.
Fixed a crash when sending GroupTrack messages.
Added support for 12-speed shifting systems.
Fixed data field issues when using a shifting system with no front derailleur.
Fixed crash when doing the FTP test.
Updated RTL510 and RTL500 light modes for Auto and Trail modes.
Fixed Varia lights not activating when starting an activity.
Fixed issue where radar would not automatically reconnect after being disconnected for more than 2 minutes.
Fixed issue where the Edge would not automatically pair with a radar that is paired to a watch that the Edge is connected to via Extended Display Mode.
Made several improvements to the Sensor Details UI for Vector 3 power meters.
Added support for displaying eBike data fields on a Varia Vision.
Fixed bug in Extended Display mode where Di2 battery would report as 255%.
Changes made from version 6.30 to 7.00 (08/01/2019):
New Beta Feature: Galileo satellites. There is now support to use the Galileo network of satellites to assist in getting GPS fixes. With the correct GPS firmware, this option can be enabled by selecting GPS+Galileo in the GPS setting. Sync the device with Garmin Express to make sure that the new line of GPS firmware is provided to the device. Without this, the option will not be available.
Added cycling dynamics support for 3rd party power sensors.
Updated smart notification categories. In the phone settings, social and other smart notification categories can be enabled. This will make the Edge show notifications from other applications depending on how they are categorized by Garmin Connect Mobile. Apps like WhatsApp, GroupMe, and Twitter may show up under social and things like e-mail, calendar, and news may show up under other. These categories are off by default and must be enabled to be seen.
Fixed an issue causing cadence and power data dropouts.
Fixed the activity profile routing mode getting reset to Road Cycling mode.
Added prompt to indicate when a course has more course points than are supported by the device.
Improved Shimano STEPS response time.
Fixed lens mode VIRB setting.
Fixed issue with transmitting front and rear gear information to the Varia Vision.
Fixed sharp bend notifications on the Varia Vision.
Fixed crash when using Varia Vision with workouts.
Fixed issue with elevation back correction that could allow large dips in elevation.
Fixed issue where the GPS data field did not match the GPS indicated by the status bar.
Fixed issue where virtual partner features were disabled for third party GPX TRK courses.
Added the current software version to the power on page.
Fixed issues with device transfers.
Completing a segment will now turn on the backlight.
Added a minimum scale to the altimeter page so that small elevation ranges are reflected properly.
Fixed elevation zooming issue with large courses/activities/segments (>100mi or km).
Improved activity auto-start when the device is stationary.
Updated radar tone to be easier to hear.
Minor bug fixes and stability improvements.
Minor CIQ improvements.
Changes made from version 6.00 to 6.30 (02/10/2018):
Fixed ANT lights support for Connect IQ.
Changes made from version 5.00 to 6.00 (23/08/2018):
New Feature: Added Connect IQ 3.0 support.
New Feature: Added Shimano STEPS sensor support.
New Beta Feature: Added extended display mode support. Select Menu > Extended Display Mode to allow the Edge device to act as an extended view of a supported Garmin multisport watch's data fields during a multi-stage activity such as a triathlon. Follow the on-screen Edge and multisport instructions to get started.
Added the ability to add CIQ data fields to the map data screen.
Improved sensor searching flow.
Fixed issue causing unexpected u-turn sharp bend warnings.
Fixed issues preventing device-to-device transfers from completing and made improvements to the connection flow.
Fixed various issues with the Varia Vision.
Fixed issue with Physio TrueUp duplicate activity detection.
Fixed issue where VO2 max could be corrupted.
Fixed issue that could cause the device to crash while connected to the phone.
Fixed bike light beam angle and light mode data field text.
Fixed the Follow a Course flow for indoor trainer mode.
Fixed issue causing Garmin Express to offer incorrect map updates.
Fixed issue allowing auto backlight to activate even when turned off.
Fixed issue that could cause light settings to not be saved.
Fixed issue causing freezes when powering off.
Fixed issue that could prevent a radar low battery message from displaying.
Changes made from version 4.00 to 5.00 (04/06/2018):
Added Physio TrueUp support. Physio TrueUp syncs activities done on other Garmin devices, allowing your device to more accurately reflect your training status and fitness. Activities from other devices will appear in the History menu. Your Training Status, Training Load, and VO2 Max will be updated using activities from your other devices, and your Recovery Time will be also updated using data from other devices supporting Physio TrueUp. Enable Physio TrueUp in Device Settings on Garmin Connect or Garmin Connect Mobile.
Improved BLE stability which addresses issues with LiveTrack and BLE sensor data freezing.
Fixed issue with 2018.10 maps where turn prompts may be missed during navigation.
Fixed an issue that could cause software updates to clear the list of paired sensors.
Fixed a crash when racing a rival effort on a segment with a long name.
Improved text message notifications by removing the requirement for Garmin Connect Mobile to have Android SMS and Contacts permissions.
Added support for receiving and replying to texts from other providers (e.g. Facebook, Google Hangouts).
Fixed crash when using audio prompts.
Fixed incorrect sharp bend warnings when riding on a course.
Fixed misaligned text when performing an address search.
Fixed issue causing saved locations to be deleted from memory.
Changes made from version 3.90 to 4.00 (01/05/2018): BUG !!!
Added enhanced support for Varia RTL510 radar tail light.
Added CIQ 2.4.4 support.
Updated touchscreen firmware to 85.11 to improve responsiveness in low temperatures.
Added the ability to discard the current ride at any time. This requires several interactions to avoid accidental discards.
Made several improvements to sharp bend warnings.
Made improvement to workout step display when set to open duration.
Fixed issue preventing immediate activity uploads after saving a ride.
Fixed issues with character encoding/decoding causing device instability.
Fixed issues with the Varia Vision data screen setup causing the Edge and Varia vision to be out of sync.
Fixed issue preventing a BLE sensor from being added if it was the first sensor.
Fixed issue where the ANT generic channel used by CIQ data fields would not reconnect when the device resumes from sleep.
Fixed issue where searching for a long address would not provide a proper result.
Fixed issue where battery save mode would turn on GPS in the Indoor activity profile.
Fixed issue preventing some iPhones from staying connected during the pairing process.
Fixed issue where the ascent remaining and ascent to next course point data field values did not match the total ascent for the course.
Fixed issue where FTP would be reset after recording an activity with a CIQ app.
Fixed issue preventing battery save mode if the timer is auto-paused.
Fixed issue where calories would be incorrectly calculated for BLE power meters.
Fixed issue causing navigation audio prompts not to work.
Changes made from version 3.80 to 3.90 (28/02/2018):
Improved device stability.
Improved Bluetooth pairing/connection for Huawei phones.
Fixed Round-Trip Course issue where ferries and tolls avoidances were being ignored.
Fixed bike light controls on the bike lights widget to send the appropriate light mode to any light.
Improved elevation profile scrolling.
Added the ability to add up to 10 custom data screens.
Fixed Lap Normalized Power data field.
Added battery status to power on page.
Added CIQ 2.4.2 support.
Fixed CIQ system fonts.
Changes made from version 3.70 to 3.80 (31/01/2018):
   Improved temperature reporting.
   Improved Bluetooth connectivity.
   Fixed issue where closing GCM on iOS would break the connection with the Edge.
   Fixed issue where BLE would remain on after disabling the phone setting on the Edge.
   Improved Edge remote connectivity.
   Fixed issues with Device Transfers.
   Fixed issues with editing power zone values.
   Enabled turn-by-turn navigation support for courses imported from GPX tracks.
   Increased automatic screen brightness in low-light conditions.
   Fixed issue preventing anti-aliased CIQ fonts.
   Fixed issue where segments were not blocked while using CIQ apps.
   Fixed issue where the widget indicator bar would not fade away while viewing a CIQ widget.
   Fixed units sync with the Varia Vision.
   Fixed issue with elapsed time when the timer is paused.
   Fixed small odometer data field to allow more digits to display.
   Fixed VAM data fields.
   Improved sharp bend warnings.
Changes made from version 3.60 to 3.70 (07/12/2017):
• Fixed Connect IQ arc drawing.
Changes made from version 3.50 to 3.60 (29/11/2017):
Added sharp bend notifications while not navigating. These notifications can be disabled by selecting Menu > Activity Profiles > [select a profile] > Navigation > Sharp Bend Warnings.
Added Connect IQ 2.4.1 support.
Added Wi-Fi support for Strava Segment Explore.
Added VIRB camera widget and VIRB 360 settings support.
Fixed issue where the turn list sent to the Varia Vision could get out of sync and cause the Edge to crash.
Fixed Training Effect inaccuracies, Training Load peaks that were over-inflated, and the Stress Score feature.
Fixed issue where segments would not display on the map and allowed the Segments activity profile option to control whether segments display or not.
Fixed issue where the Edge would not receive sensor software updates.
Fixed issue causing erroneous GPS position on iPhone.
Improved graphics performance.
Made stability improvements.
Changes made from version 3.40 to 3.50 (19/10/2017):
Fixed issue causing the map to crash.
Changes made from version 3.20 to 3.40 (11/10/2017):
Added Shimano Di2 2.0 support.
Added Vector 3 software update support.
Improved Grade accuracy on steep climbs.
Fixed issue preventing activities from being saved on an SD card.
Fixed several Varia Vision issues.
Fixed issues with performance condition display and data recording.
Fixed issue preventing training status and training load from being uploaded to Garmin Connect.
Fixed an issue allowing Connect IQ Apps to disable sensors.
Fixed issue causing the back key to not display in CIQ apps.
Fixed issue causing crashes when using 3D map mode.
Fixed issue that could cause a crash while using Strava Segment Explore map preview.
Updated recovery time calculation requirements. To trigger a recovery time, ride with a heart rate sensor for ten minutes at moderate to high intensity.
Changes made from version 2.30 to 3.20 (06/09/2017):
Added the ability to customize the lap banner with up to four data fields.
Added Di2 Synchroshift support.
Improved the user interface for Vector setup.
Improved elevation accuracy.
Improved widget loop by returning to the most recently used widget.
Increased transfer speed for the Strava Segment Explore widget and the Strava Routes CIQ app.
Fixed issues with segment processing.
Fixed issues with device-to-device transfers.
Fixed issues with My Stats data calculations and UI.
Fixed an issue that could prevent bike light networks from reforming.
Made numerous stability improvements, bug fixes, and UI improvements.
Edge 1030 software version 7.50 du 13/06/2019 Empty Re: Edge 1030 software version 7.50 du 13/06/2019
Message par Monique le Sam 28 Oct 2017 - 18:27
version 3.50 disponible
Message par Utvara le Sam 25 Nov 2017 - 20:16
Version 3.58 Beta disponible
Utvara
Message par Tixu le Sam 25 Nov 2017 - 22:59
oui, mais franchement décevante cette beta, au regard des bugs existants et remontés, et de ce qui est annoncé comme correctifs dans celle ci
Tixu
Message par Utvara le Dim 26 Nov 2017 - 20:33
Possible, moi je suis déjà content, j’ai plusieurs trucs qui fonctionne enfin comme ils doivent.
Mais c’est sur qu’on est loin du compte :-)
Utvara
Message par Utvara le Ven 1 Déc 2017 - 19:10
la 3.60 officielle est disponible
[EDIT de Monique : Merci, post 1 mis à jour]
Utvara
Message par Tixu le Mer 13 Déc 2017 - 0:54
la 3.70 officielle est disponible
Tixu
Message par Monique le Mer 13 Déc 2017 - 8:06
Merci Tixu. Le site de Garmin affichant toujours la version 3.60, j'ai trouvé les notes de version de la 3.70 sur le forum Garmin US... ce sera donc à vérifier dans quelques jours.
Message par Utvara le Jeu 11 Jan 2018 - 23:00
Version 3.74 dispo
Utvara
Message par Tixu le Jeu 11 Jan 2018 - 23:06
New Public Beta 3.74 Now Available
Today, 09:53 PM
A new Beta software for the Edge 1030 has been released. Full change log, instructions, and software for installing the beta can be found here.
Notes:
For any issues that you encounter please fill out the form included in the download and attach it to an email [Vous devez être inscrit et connecté pour voir ce lien]. Please note that you may not get a response to the email unless we need more information on the issue you report.
In the process of troubleshooting reported issues we may access information in your Garmin Connect account, such as your activity files. More information about Garmin's privacy policies can be found at: [Vous devez être inscrit et connecté pour voir ce lien]
Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 3.70 to 3.74:
Installation Instructions
Connect your Edge 1030 device to your computer using the micro-USB cable.
Download and unzip Edge1030_374Beta.zip and place the GUPDATE.gcd file in the \Garmin folder of your device's internal storage drive.
Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
If you would like to revert to the last public release software, follow the above steps but place the GUPDATE-370.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
Tixu
Message par Monique le Ven 12 Jan 2018 - 7:55
Merci à tout les deux.
PS : Je ne note pas les versions Beta (pas encore stables, utilisées pour tester) dans le 1er post.
Message par Utvara le Mar 23 Jan 2018 - 22:13
La 3.77 beta vient remplacer la catastrophique 3.74
Utvara
Message par Utvara le Mer 31 Jan 2018 - 20:19
Et la 3.8 est annoncée (déploiement en cours)
Amélioration des rapports de température.
Connectivité Bluetooth améliorée.
Correction d'un problème où la fermeture de GCM sur iOS rompait la connexion avec Edge. Correction du problème où BLE resterait après avoir désactivé le paramètre du téléphone
Connectivité distante Edge améliorée.
Correction de problèmes avec les transferts de périphériques.
Correction de problèmes liés à l'édition des valeurs de zone de puissance.
Prise en charge de la navigation virage par virage pour les parcours importés à partir de pistes GPX.
Augmentation de la luminosité de l'écran automatique dans des conditions de faible luminosité. Correction d'un problème empêchant les polices CIQ anti-aliasées.
Correction d'un problème où les segments n'étaient pas bloqués lors de l'utilisation des applications CIQ.
Résolution du problème suivant: la barre d'indicateurs du widget ne disparaissait pas lors de l'affichage d'un widget CIQ.
Les unités fixes se synchronisent avec Varia Vision.
Correction d'un problème avec le temps écoulé lorsque la minuterie est en pause.
Correction d'un petit champ de données d'odomètre pour permettre l'affichage de plus de chiffres.
Correction des champs de données VAM.
Avertissements de virage serrés améliorés.
Stabilité améliorée de l'appareil.
Utvara
Message par Monique le Ven 2 Fév 2018 - 8:31
Merci. Elle n’apparaît pas encore sur le site de Garmin (mon lien du post 1) mais sur le forum Garmin US (ICI).
Message par Utvara le Ven 2 Fév 2018 - 10:21
Effectivement hier j ai demandé ce qu' il en était et le déploiement devrait passer de 20% à 50% aujourd'hui. Mais je ne sais pas pourquoi pas tout le monde d un coup.
Utvara
Message par Monique le Ven 2 Fév 2018 - 10:23
Peut-être pour limiter la saturation des serveurs de Garmin Question
Message par Utvara le Ven 2 Fév 2018 - 22:48
Oui ca évidemment mais pourquoi cette fois ci et pas les autres ?
Enfin bref, ca y est (pour moi ) la mise a jour est dispo
Utvara
Message par Utvara le Mer 28 Fév 2018 - 19:51
Le deploiement en cours pour la 3.90
Elle est la version utilisateur des bétas 3.82 et 3.85 qui sont (enfin) au niveau (a vrai dire, les meilleurs versions que j''ai essayées)
Appariement / connexion Bluetooth amélioré pour les téléphones Huawei.
Correction d'un problème de parcours aller-retour où les ferries et les évitements de péages étaient ignorés.
Les commandes d'éclairage de vélo fixes sur le widget des lumières de vélo pour envoyer le mode d'éclairage approprié à n'importe quelle lumière.
Défilement du profil d'élévation amélioré.
Ajout de la possibilité d'ajouter jusqu'à 10 écrans de données personnalisés.
Champ de données de puissance normalisée.
Ajout de l'état de la batterie pour allumer la page.
Ajout du support de CIQ 2.4.2. Correction des polices système CIQ.
Utvara
Message par Monique le Ven 6 Avr 2018 - 10:08
Merci, j'ai mis le post 1 à jour. Par contre, le site de Garmin indique la date du 27/02/2017 pour cette version (au lieu du 28/02/2018).
Edge 1030 software version 7.50 du 13/06/2019 Empty Edge 1030 problème avec BaseCamp
Message par phjmvuil le Jeu 17 Mai 2018 - 9:34
Avec la version 4.0 du logiciel, dans certains cas, il n'est pas possible de charger un parcours depuis BaseCamp sur l'Edge 1030. Le parcours s'enregistre bien dans le directoire "GPX" mais il n'est pas possible de le retrouver dans "Parcours" sur le GPS. (Navigation --> Parcours --> Parcours enregistrés : aucun parcours n'est enregistré)
Il s'agit d'un bug de la version 4.0. Il est corrigé dans la version 4.11 beta. Il semblerait que d'ici à fin mai Garmin fasse d'importante MàJ ...
Meilleures salutations
[EDIT de Monique : Merci. sujet fusionné avec le sujet en cours]
phjmvuil
Message par Monique le Jeu 17 Mai 2018 - 10:20
Bonjour phjmvuil,
Merci pour ce retour. J'ai fusionné ton sujet avec celui des mises à jour du Edge 1030.
Edge 1030 software version 7.50 du 13/06/2019 Empty connexion Edge 1030 v4
Message par ATLI le Lun 4 Juin 2018 - 10:30
Sur mon Edge 1030, Je bénéficie de la V.4.00...
et depuis quelques semaines, je ne peux transférer mes parcours par mapsource, message: "Un problème de connexion avec l’appareil Garmin s’est produit GARMIN(E:\). La connexion avec l’appareil peut être maintenue et les fonctionnalités réduites….
Veuillez contacter l’assistance …"
Même situation pour faire une mise à jour par WebUpdater, il reconnait les deux disques, mais pas le (Garmin Edge...)
Les mises à jour par Garmin Connect, fonctionnent.
J'ai également eu des soucis appairage/BT, et donc de suivi/Livetrack, mais tout fonctionne désormais, depuis une semaine.
Avec un Edge 1000, je n'ai pas ce problème d'identification!...
Est-ce un bug/Edge 1030, ou ?
ATLI
Message par Monique le Lun 4 Juin 2018 - 11:51
Probablement... lis le titre de ce sujet et le commentaire plus haut :
Le 17 Mai 2018 - 9:34, phjmvuil a écrit:Avec la version 4.0 du logiciel, dans certains cas, il n'est pas possible de charger un parcours depuis BaseCamp sur l'Edge 1030. Le parcours s'enregistre bien dans le directoire "GPX" mais il n'est pas possible de le retrouver dans "Parcours" sur le GPS. (Navigation --> Parcours --> Parcours enregistrés : aucun parcours n'est enregistré)
La version 4.36 Beta est ici : [Vous devez être inscrit et connecté pour voir ce lien]
Message par ATLI le Lun 4 Juin 2018 - 14:36
Parfait, résolu,
ATLI
Message par Monique le Mar 12 Juin 2018 - 21:14
version 5.00 disponible
