Edge 1030 software version 7.20 du 13/03/2019
Page 2 sur 2 Précédent  1, 2
Re: Edge 1030 software version 7.20 du 13/03/2019
Message par ATLI le Mar 12 Juin 2018 - 21:35
Merci, c'est fait, mais les connections Bluetooth/Iphone, sont toujours laborieuses... et instables,= pertes de connection/suivi avec Livetrack.
ATLI
Message par Tixu le Sam 25 Aoû 2018 - 8:34
Sortie de la version 6.00
Changes made from version 5.00 to 6.00
New Feature: Added Connect IQ 3.0 support.
New Feature: Added Shimano STEPS sensor support.
New Beta Feature: Added extended display mode support. Select Menu > Extended Display Mode to allow the Edge device to act as an extended view of a supported Garmin multisport watch's data fields during a multi-stage activity such as a triathlon. Follow the on-screen Edge and multisport instructions to get started.
Added the ability to add CIQ data fields to the map data screen.
Improved sensor searching flow.
Fixed issue causing unexpected u-turn sharp bend warnings.
Fixed issues preventing device-to-device transfers from completing and made improvements to the connection flow.
Fixed various issues with the Varia Vision.
Fixed issue with Physio TrueUp duplicate activity detection.
Fixed issue where VO2 max could be corrupted.
Fixed issue that could cause the device to crash while connected to the phone.
Fixed bike light beam angle and light mode data field text.
Fixed the Follow a Course flow for indoor trainer mode.
Fixed issue with the device where going into mass storage from a power off state may cause Garmin Express to offer a map update that the device does not need.
Fixed issue where auto backlight could activate despite the setting being turned off.
Fixed a light settings vulnerability that could cause the light settings to not be saved.
Fixed a potential freeze when powering off.
Fixed an issue that could prevent a radar low battery message from displaying.
Prevented crashes caused by adding new segment files during an activity.
[EDIT de Monique : Merci, post 1 mis à jour]
Tixu
Message par Monique le Ven 12 Oct 2018 - 11:51
version 6.30 disponible
Message par Monique le Dim 6 Jan 2019 - 10:18
J'ai déplacé les messages de Boleotango pour créer un nouveau sujet ici (cliquer sur le lien au-dessous) :
Message par Monique le Sam 12 Jan 2019 - 16:50
version 7 disponible
Message par Monique le Sam 12 Jan 2019 - 17:10
version 7.00 disponible
Message par Monique le Sam 16 Mar 2019 - 20:39
version 7.20 disponible
