Fenix 6, 6 Pro, 6S, 6S Pro et 6X Pro version 12.20 du 20/10/2020
Fenix 6, 6 Pro, 6S, 6S Pro et 6X Pro version 12.20 du 20/10/2020 Empty Fenix 6, 6 Pro, 6S, 6S Pro et 6X Pro version 12.20 du 20/10/2020
Message par Monique le Lun 30 Déc 2019 - 19:54
- fenix 6 software version : ICI
- fenix 6 Pro software version : ICI
- fenix 6S software version : ICI
- fenix 6S Pro software version : ICI
- fenix 6X Pro software version : ICI
Tuto pour effectuer la mise à jour via WebUpdater : [Vous devez être inscrit et connecté pour voir ce lien]
Change History :
Changes made from version 11.10 to 12.20 (20/10/2020):
Added support for Daily Suggested Workouts, which are recommended based on previous activities. One can disable this from activity settings. (Run/Bike > Menu > Training > Workouts > Today's Suggestion.)
Added support for the Track Run activity, which allows one to record outdoor track data including distance in meters and lap splits on a standard shape 400m track.
Added support for Improved Recovery Time, which takes users stress, sleep, relaxation and physical activity in consideration.
Added support for configuring non-zero power averaging for Biking activities. (Activity Settings > Power Averaging)
Added support for configuring backlight settings during the sleep window. (Settings > System > Backlight > During Sleep.)
Added support for training and breathwork workout categories to properly handle launching workouts from calendar view and prompting yoga, strength, cardio, breathing, and pilates workouts.
Added Training Status explanation tip in the Training Status widget.
Added support for displaying the map scale when panning/zooming the map.
Fixed an issue where the ‘Navigation’ hotkey was not working as expected for certain use cases.
Fixed an issue with the wind speed data field on watch face.
Fixed an issue where open water swim activities were capturing an erroneous position in the track log.
Fixed an issue where the device would fail to load the elevation plot when navigating to a POI.
Fixed an issue where the elevation plot would intermittently get doubled while navigating.
Fixed an issue where expired weather data was being displayed on the watchface.
Fixed a couple of issues with the Sail Race activity. (Quatix 6 only)
Fixed an issue where time in zones information could be incorrect for pool swim activities.
Fixed potential GPS communication problems. (Requires GPS v4.60)
Improved the pairing experience for Bike lights/radar.
Improved compass smoothness.
Improved poor wrist HR detection which will lead to more accurate VO2 Max and Performance Condition estimates.
Updated the Clocks list layout and icons.
Updated the Applied Ballistics bullet database to version 1155 (tactix Delta AB only).
Changes made from version 10.10 to 11.10 (26/08/2020):
Added additional options to Live Event Sharing. Triggers added for Every Mile and Transitions (allowing for multi-sport use)
Added the Pause Training Status feature. Allows the user to suppress some training status feedback phrases and trends. Access the options from the Training Status widget menu or within Garmin Connect.
Added support for displaying courses to viewers of user's LiveTrack sessions.
Added support for FE-C and Smart Trainer control. See options in Bike Indoor activity.
Added support for configuring map settings during an Expedition activity.
Added support for battery hours remaining as a data field option.
Added support for displaying running and cycling VO2 Max for a multisport activity when applicable.
Added support for canceling a route when in simple tracking mode for Indoor Climb.
Improved Bluetooth stability and reliability.
Improved the music experience on device.
Fixed an issue where summary activities (sync’ed from another device) were showing up in the list of navigable activities.
Fixed an issue where smart notifications received in quick succession would not populate its options correctly.
Fixed an issue where the device would fail to save an activity and the progress spinner would spin indefinitely.
Changes made from version 9.00 to 10.10 (08/07/2020):
   Added support for on device sleep. (Requires Sensor Hub 7.11)
   Added support for Surf activity.
   Added support for Altitude Acclimation widget. (Menu > Widgets > Edit > Add > Alt. Acclimation)
   Golf: Added support for golf tournament UI.
   Golf: Added support for 9+9 round, where the user can select a teebox for both courses.
   Added support for viewing recovery heart rate from the activity paused menu.
   Added support for the Steps data field.
   Improved Broadcast Heart Rate and added support for simultaneously broadcasting through ANT+ and Bluetooth.
   Made several improvements to Indoor Climb.
   Improved data reliability for the weather widget.
   Improved the visibility for inReach and Dogtrack by allowing one to pair to them through the sensors menu and automatically removing the widgets once the sensor is removed.
   Updated the user interface for several widgets.
   Fixed an intermittent issue with map load times and map responsiveness.
   Fixed an issue where the 'Around Me' search would not complete intermittently.
   Fixed an issue where playlists with Cyrillic characters would not display correctly on device.
   Fixed an issue where the altitude would drop to 0 every night. (Fenix 6 non-Pro devices.)
   Fixed an issue where alarm labels were not being translated.
   Fixed an intermittent issue where the weather widget would fail to load data when connected to an iOS device.
Changes made from version 8.10 to 9.00 (01/05/2020):
Added support for Indoor Rock Climbing. Easily track the number of routes and ascent with automatic climb detection. One can also enable 'Route Stats' to log route difficulty, number of falls, attempts and completions.
Added support of Bouldering. Use the LAP key to start/end routes at the gym. One can also log route difficulty, number of attempts or completions.
Added support for Grit and Flow metrics to the Mountain Biking activity, which measure the difficulty and performance of each ride.
Added support for downloading workout videos over Express or WiFi.
Updated the look and feel of several widgets and the End of Activity flow.
Changes made from version 6.10 to 8.10 (23/03/2020):
Added support for Virtual Running. (Download the Zwift mobile app and launch the “Virtual Run” activity profile on your Garmin device.)
Added support for connecting to a shifting sensor (Sram Etap or Di2 bike) that supports up to 4 front and 12 rear gears.
Added support for a ‘Silent’ option to the Smart notifications Sounds alert settings. (Menu > Phone > Smart Notifications > During Activity/Not During Activity > Sounds)
Improved the user experience when call related notifications are received.
Improved the layout on the Ski Run Data Page.
Improved error handling when using the Garmin Pay Wallet.
Made some improvements to the DogTracker widget.
Made several improvements to Clock.
Made several improvements to Breathwork.
Made several improvements to the music experience.
Fixed an issue where the watch may freeze during a Ski activity.
Fixed a couple of altimeter calibration issues. This should address speed spikes in activities with 3d speed enabled. (For example: Ski.)
Fixed an issue with Brazil Daylight savings time.
Fixed an issue where the device may crash when nearing the end of a climb, when using ClimbPro
Fixed an issue where the device would always display the 'Updating' spinner when changing an alarm.
Fixed an issue where certain workout names were not displaying correctly during a rest step.
Fixed an issue where selection of an item in music lists (artist/genre) would yield a landing page for a different artist/genre.
Fixed an issue where the device won’t tone/vibe at the end of a swim rest interval.
Fixed an issue where advanced power fields were missing from the Biking activity.
Changes made from version 6.00 to 6.10 (12/02/2020):
Improve Wi-Fi sync connection stability.
Changes made from version 5.00 to 6.00 (23/01/2020):
Added support for Swim2 features namely, Auto Rest, Swim Time data field, Swim workout improvements, Pacing Alerts, Swim Dead Reckoning for OWS and Critical Swim Speed.
Made several improvements to the DogTracker widget and on device experience. This includes: New Tracker Map, Pro View, Compass pages and new Alert options on device.
Added support for Action Menu with the Expedition App.
Added support for Low Heart Rate Alerts. (Wrist Heart Rate > Heart Rate Options > Abnormal HR Alert)
Added support for configuring intensity minutes based on HR zones. Configuration is only available on Garmin Connect.
Added a new digital watch-face option which displays minutes as the large value in the center.
Updated the look and feel of Clocks to provide a more condensed version of the information at a glance.
Fixed an issue with treadmill calibration.
Fixed an issue where the device would crash when starting a POI search right after canceling an ‘Around Me” search.
+ Pour les modèles 6 Pro et 6X pro uniquement : Fixed an intermittent issue that could lead to rapid battery drain on music products.
Changes made from version 4.30 to 5.00 (04/12/2019):
Added Backcountry Ski App. Switch modes using the LAP key to track your stats as you ski off the beaten path.
Added support for Action Menu during Golf. This should provide a more consistent and discoverable way to access more functions (actions) using the 'Start' key.
Added support to auto enable Battery Saver during Sleep. (Menu > Power Manager > Battery Saver > During Sleep.)
Added support for disabling workout videos during an activity. (Activity (Strength/Yoga/Pilates/Cardio) > Settings > Workout Videos)
Added support for workout video preview. The user will now be able to view the video and notes for each step from the 'View' option in the workout menu.
Added support for Airplane Mode, which allows the user to disconnect from all wireless communication namely Wi-Fi, Bluetooth and ANT. (Hold Light > Controls > Hold Up > Add Controls > Airplane Mode)
Added support for file based Emojis, which brings support for over 1300 Emojis. (Update your device through Express or connect it to Garmin Connect Mobile.)
Added support for ClimbPro 'Climb Detection' setting in Cycling. (Bike > Activity Settings > ClimbPro > Climb Detection) This allows the customer to customize grade 'sensitivity' when identifying climbs.
Improved ClimbPro for cycling by adding category coloring to the ascent graph, which better depicts the difficult portions of the climb. This will also be available when reviewing the elevation plot for a course.
Updated the Alt. Time Zones widget with an improved selection process incorporating time zones for over 450 different cities worldwide.
Improved connection reliability with iPhone 11 and some Samsung Galaxy phones.
Improved compass performance.
Improved the Respiration widget and the Breathwork activity.
Fixed an issue where the device may become unresponsive when trying to navigate certain types of PacePro enabled courses.
Fixed an issue where the stress score could intermittently get stuck at 25.
Fixed a connection issue with the Running Dynamics pod.
Fixed an issue where the connection state of Speed/Cadence sensors was not updating properly.
Fixed an issue where the course list page appeared to skip a course when scrolling. (Non-Pro models only.)
Fixed an intermittent issue where the map would switch to a Dark theme when previewing a PacePro course.
Pulled in support for WHR v20.04.50. (Requires SNS v3.10)
Brought in several improvements for music.
Changes made from version 4.20 to 4.30:
Fixed Wi-Fi 0200 Error when syncing Spotify.
Changes made from version 4.10 to 4.20:
Fixed an issue where the stress data field wasn't working as expected during Yoga and Breathwork activities.
Fixed an issue with changing the music player volume on device.
Fixed an intermittent issue where Auto Uploads via WiFi were not working as expected.
Changes made from version 3.00 to 4.10:
Added support for on-device videos demonstrating workout steps. These are available for the pre-loaded workouts now available in Yoga, Strength, Cardio, and Pilates apps. Additional workouts with support for on-device videos can be downloaded from Garmin Connect. Note: Videos are only available on Pro and Sapphire models.
Added support for configuring power modes during an activity. (Activity Settings > Power Mode > Default Mode.)
Added support for configurable low battery alerts. (Settings > Power Manager > Battery Saver > Low Battery Alert)
Added support for all day respiration rate tracking (Widget > Menu > Add Widget > Respiration) and a Breathwork activity. (Requires SNS v2.50)
Added support for turning Wi-Fi off from power controls and improved the sync experience by falling back to Wi-Fi, if phone syncs fail.
Added support for inReach display verification, when using authentication.
Brought in bug fixes and code improvements for CIQ SDK v3.1.
Improved the widget loop editing (add, remove, reorder) experience when using glances. (Widget > Menu > Reorder Widget\Add Widget OR Menu > Widgets > Edit.)
Improved altitude calibration for non-Fenix 6 pro/sapphire models.
Made several improvements for CIQ music apps.
Changes made from version 2.20 to 3.00:
Initial Release.
Fenix 6, 6 Pro, 6S, 6S Pro et 6X Pro version 12.20 du 20/10/2020 Empty Re: Fenix 6, 6 Pro, 6S, 6S Pro et 6X Pro version 12.20 du 20/10/2020
Message par Monique le Mer 5 Fév 2020 - 9:03
version 6.00 disponible
Message par Monique le Jeu 12 Mar 2020 - 18:46
version 6.10 disponible
Message par Monique le Sam 4 Avr 2020 - 18:41
version 8.10 disponible
Message par Monique le Dim 10 Mai 2020 - 7:41
version 9.00 disponible
Message par Monique le Sam 8 Aoû 2020 - 19:52
version 10.10 disponible
Message par Monique le Lun 31 Aoû 2020 - 11:48
version 11.10 disponible
Message par Monique le Sam 31 Oct 2020 - 21:01
version 12.20 disponible
