Edge 1030 Plus software 5.20 du 22/07/2021
Edge 1030 Plus software 5.20 du 22/07/2021 Empty Edge 1030 Plus software 5.20 du 22/07/2021
Message par Monique Ven 4 Juin 2021 - 10:32
Edge 1030 Plus software version  LÀ (sur les forums Garmin US)
Note : Pour un Edge 1030 c'est : [Vous devez être inscrit et connecté pour voir ce lien]
Instructions à suivre pour les fichiers postés sur le forum US :
Branchez votre appareil Edge sur USB.
Téléchargez et décompressez le fichier de mise à jour
Placez le fichier GUPDATE.gcd dans le dossier \ Garmin du lecteur de stockage interne de votre appareil.
Éjectez l'appareil de l'USB et attendez la fin de la mise à jour.
Change History :
Changes made from 5.10 to 5.20 (22/07/2021):
Fixed issue with Fazua BLE Scanning
Fixed issue with viewing incidents on the map
Changes made from 4.10 to 5.00 (14/06/2021):
Course Routing
- Improved course routing speed.
- Added automatic course route caching.
Map
- Improved map visibility and contrast with new map themes.
- Added a popularity layer to highlight roads that Garmin users have ridden the most.
- Added directional arrows to routes, courses, and history lines.
Phone
- Added smart syncing before an activity.
- Added a Sync Now button to the settings widget and the Connected Features > Phone menu.
Updated Firstbeat library for various improvements and bug fixes including a fix for training stats being reset on a multiple day activity.
CIQ
- Fixed issue with BLE sensors in CIQ data fields after waking the Edge from sleep mode.
- Fixed issue where activity controls would not work in a CIQ app.
- Improved CIQ data field settings experience by always prompting when adding a settings-capable CIQ data field.
- Increased font size for app background messages.
- Fixed other minor issues.
Fixed several inReach issues.
Improved Garmin dual-mode sensor management.
Improved power meter calibration and software updates.
Improved the cycling dynamics page.
Increased maximum number of workout steps from 50 to 100.
Combined the indoor trainer Target Power and Resistance data fields into a single new "Trainer Mode Value" data field that will dynamically change the title and value based on the current trainer mode between Target Power, Slope, and Resistance options.
Added support for including metabolic calories in the total calories reported in the calories data field and recorded in the activity file.
Fixed manual elevation calibration.
Fixed issue with blank Strava segments appearing on the Segment Explore widget.
Fixed minor bugs.
Improved device stability.
Changes made from 4.00 to 4.10 (05/02/2021):
-Fixed issue preventing Wi-Fi certificates from being acquired.
Versions précédentes :
- 4.00 (19/11/2020)
- 3.00 (20/08/2020)
- 2.30 (17/06/2020)
Edge 1030 Plus software 5.20 du 22/07/2021 Empty Re: Edge 1030 Plus software 5.20 du 22/07/2021
Message par Monique Mar 22 Juin 2021 - 13:44
version 5.00 disponible
Message par Monique Jeu 15 Juil 2021 - 8:20
Les commentaires de michle38 ont été déplacés, ce sujet ne sert qu'à indiquer les nouvelles versions du software.
Message par Monique Dim 25 Juil 2021 - 19:48
version 5.20 disponible
