Edge Explore 2 version 10.23
Edge Explore 2 software version : (cliquer) ICI (sur forums Garmin US)
Changes made from version 9.07 to 10.23 (01/09/2023):
Added the GroupRide feature.
Added navigation shortcut in map banner.
Added additional map data screen layouts, allowing for up to four data screens when the elevation profile is hidden.
Enabled alphanumeric postal code when using the search feature.
Persisted ClimbPro map zoom levels when auto zoom is off.
Fixed remaining battery life estimate.
Fixed straight line navigation.
Changes made from version 8.06 to 9.07 (22/05/2023):
Added support for customizing canned text responses on the Garmin Connect mobile app (Android only).
Added ability to send "I'm Okay" message from device if incident messages have been sent.
Added Demo mode.
Fixed cursor disappearing on home screen.
Fixed battery charging issue in certain use case.
Changes made from version 7.09 to 8.06 (15/02/2023):
Added support for CIQ System 6
Added Additional Emoji Support
Added feedback to RCT 715 Save Photo and Save Video buttons
Fixed bugs and improved stability
Changes made from version 6.05 to 7.09 (23/12/2022):
Added support for live event sharing
Added support for spectator messaging
Added support for heart rate confidence metric
Added RCT715 recording status indicator
Added support for saving photos and video clips on the RCT715 when the camera is disabled or busy.
Added support for turning off RCT715 video recording when suspending or powering off the Edge.
Improved phone pairing experience by adding QR code support and supporting PIN comparison when used with a compatible smartphone
Improved ClimbPro data screen and climb list
Fixed various bugs and improved product stability
Changes made from version 6.04 to 6.05 (20/09/2022):
Fixed crash when connected to external battery
Changes made from version 5.09 to 6.04 (29/08/2022):
Fix an issue that doesn't respect ClimbPro settings.
Fix Edge Remote control behavior.
Fix bug for indoor trainer course.
Fix Connect IQ issues.
Fix crash issues.
Add radar alert awareness warning on first connect.
Improve touch behavior in widget loop.
version 5.09 (16/08/2022):
Add Music Control feature.
Add Fitness Age feature.
Add Intensity Minutes feature
Added Demo mode.
Fix crash issues.
» Remarques sur les versions des Edge Explore 2
» Edge Explore 2 - Piste Cyclable
» edge explore 2. détection dans basecamp
» Edge Explore 2 et stick USB ANT+ Garmin pour transfert de données avec son PC
» Edge EXPLORE 2 enregistrer une trace en activité VTT
