Info anciennes cartes bluechart 9.5
Bonjour à tous
On a le droit d'utiliser les versions Blue chart 8,5 and Blue chart 9,5 sur deux GPS d'après la licence.
Impossible de charger mes cartes légales sur le gps recu à Noel !!!, Ce sont de vielles cartes, mais on n'a quasiment pas de mise à jour en Guyane Française et elles font parfaitement l'affaire.
J'ai un peu grogné sur le support GARMIN et voici la réponse: Vous y avez droit, mais on a fermé les bases de données.
C'est un peu limite comme réponse.
Thank you for contacting Garmin International. I would be happy to help you with this today. I am sorry to hear that you have not been satisfied and that you are having difficulty with your Bluechart maps. Unfortunately, Garmin has discontinued the traditional BlueChart software. The last version of the traditional BlueChart mapping was created in July of 2008 and was called BlueChart 2008.5. The mapping will not be updated past this point.
As of December 15th, 2011, Garmin has turned off the BlueChart unlock process. This means that any old version of BlueChart mapping cannot be updated to a newer version as an unlock code for the new version cannot be generated. It is no longer possible to update any version of the traditional BlueChart mapping.
Unfortunately, the second unlock code is no longer available at this time because the database for the Bluechart program that generates the unlock codes has been shut down.
If the mapping has disappeared from your device, please re-download the maps to your GPSmap 60CSx from your computer.
I apologize for any inconvenience this may have caused you. Please let me know if there is anything else I may further assist you with.
1200 E. 151st Street
Olathe, KS 66062
With Best Regards,
Melissa M
Product Support Specialist
Automotive - Marine Team
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Melissa M, Associate #5731
Additional solutions may be found at [Vous devez être inscrit et connecté pour voir ce lien]
Olathe, KS 66062
With Best Regards,
Melissa M
913-397-8200
800-800-1020
gcoly- 0 sat
Re: Info anciennes cartes bluechart 9.5
je crains qu'il n'y ait pas de solution -du moins officielle/légale-; c'était la même chose (en pire en ce qui concerne les délais) pour les carto routières, du temps où elles pouvaient être déverrouillées pour 2 GPS: si on n'utilisait pas la possibilité d'activer un 2ème GPS avant la sortie de la version suivant de la carto (donc 1 an grand maximum), cette 2ème possibilité était perdue.
» Cartes marine type Bluechart
» reconnaissance des cartes bluechart sur basecamp
» Compatibilité 60 CSx et cartes BlueChart G2 Vision
» Mise à jour des cartes Bluechart g2 vision
» Bug Garmin Bluechart
