BASECAMP 4.3.1 fr
+11
jj.barberousse
jmt491
Xtian74
Ramus80
moi.93
Sergio
VTTRANDO
michel580
15 participants
Page 1 sur 2
Page 1 sur 2 • 1, 2
BASECAMP 4.3.1 fr
Voici le lien pour le nouveau Basecamp 4.31 :[Vous devez être inscrit et connecté pour voir ce lien]
Bien désinstaller la version précédente et effacer le répertoire Basecamp dans c:\program files (x86) \garmin\basecamp sinon il pourrait y avoir des erreurs au démarrage du logiciel.
Je n'ai pas le détail des nouveautés...à tester.
michel580- 2 sat
Re: BASECAMP 4.3.1 fr
BaseCamp pour Windows
Ver . 4.3.1 - 13/05/2014
Added waypoint categories to the waypoint and bulk waypoint property dialogs.
Added the Task Based Startup Menu allowing users to choose what they want to do giving more help into what BaseCamp can do.
Added an Address search UI that operates more like MapSource.
Added Find Intersection to the Find menu.
Added richer context menus in most tools on the map.
Added feature to calculate a route that tries to match the shape of a track.
Added feature to optimize routes within trip planner.
Added a way to make it easier to find recently downloaded BirdsEye imagery.
Added a way to filter Adventures by activity when using Find.
Added indication of Adventure selected on the map.
Added display of route stats while editing the route on the map.
Added display of track stats while editing the track on the map.
Added a device information dialog.
Added support for curvy road route calculation.
Added 'snap to' indicator on the map when drawing new points in a route.
Added ability to exclude track portions in the track join dialog.
Added an 'Off Road' profile and clarified the difference between Off Road and ATV.
Added a prompt to preserve the original tracks when joining tracks.
Added a hotkey to open and close the overview map.
Added elevation statistics to the route dialog.
Added statistics display to the bulk route properties dialog.
Added ability to remove shaping points from routes in the data list.
Added display of rubber band when moving a waypoint on the map.
Added display of state and country city search results.
Added ability to create lists in the 'Send To' dialog.
Added an 'uncheck all' option when managing Custom POIs.
Added support for Lat/Lon coordiantes that are missing cardinal direction indicators.
Added a comment column for tracks in the data list.
Added more descriptive messages if export errors are encountered.
Added FIT file support to the Import dialog.
Improved performance when device maps are discovered for the first time.
Improved address search on device or card maps.
Improved balloons on the map.
Improved drawing performance of large tracks and routes.
Improved performance of filtering a track.
Improved waypoint search performance.
Improved discoverability of Adventure Edit, Publish, and View Online actions.
Improved display of individual track portions in the track join dialog.
Improved device communications performance when transferring photos.
Improved notification that a subscription is needed for a selected BirdsEye product.
Improved recovery from corrupted cache information from device maps.
Simplified default toolbar layout to exclude some editing tools.
Changed the map product selection combobox to be hidden in the default layout.
Fixed issue with encrypted Custom POI search (for RV and dezl devices).
Fixed issues with routes that have multiple transportation modes.
Fixed device calculated ascent and descent values not being displayed.
Fixed Trip Planner crash when adding food stops to trips.
Fixed Basestation not updating most recent update time for contacts.
Fixed issue with reading photo waypoints that had missing photos.
Fixed map points remaining on the map after turning off all points.
Fixed Adventure playback not taking track speed into consideration.
Fixed a possible error when creating backup files.
Fixed issue with inverted routes maintaining previous departure times.
Fixed various language translations.
Removed printing restriction for card and device based map products.
[Edit Jamas] retour à la VO, la traduction en français étant très (trop) mauvaise
Dernière édition par Jamas le Mer 21 Mai 2014 - 0:40, édité 1 fois (Raison : Edit Jamas: retour à la VO, la VF etant très (trop) mauvaise)
michel580- 2 sat
BonjourVTTRANDO a écrit:Bonjour,
J'ai XP c'est compatible ???
1ere ligne du lien ci dessus a lire
si on donne des liens, c'est pour qu'ils soient lus ....
Sixun a écrit:BonjourVTTRANDO a écrit:Bonjour,
Merci pour cette réponse sympa..
VTTRANDO- 3 sat
Hello
J'ai la version 4.2.5 et quand je fais rechercher une mise à jour, il me dit : '' aucune mise à jour n'est disponible''
Ramus80- 4 sat
La MAJ avec le lien du précédent post s'effectue sans problèmes avec mon viel ordi sous Vista, avec conservation de la collection.
Sergio- 7 sat
Ciao
Ciao
Xtian74- 4 sat
Bonjour le progrés
Garmin
Bonjour le progrés
Spécifications Système pour la version 4.3.1:
- Windows Vista Service Pack 2 ou ultérieur est nécessaire
- Les PC's avec XP SP3, Vista sans le "Service Pack" ou Vista avec le " Service Pack 1" doivent utiliser la version 4.2.5 de BaseCamp
- .NET framework 4.5 SP1 est nécessaire.
- Windows Media Player 11 ou ultérieur est nécessaire
- 1 Go de mémoire RAM est nécessaire, 2 Go recommandé lors de l'utilisation de cartes BirdsEye ou des "Custom Maps" Garmin.
- Une carte vidéo supportant OpenGL version 1.3 ou ultérieur est nécessaire pour obtenir les vues 3D.
- BaseCamp est compatible de tous les cartes MapSource sauf BlueChart.
- BaseCamp n'est pas compatible avec les GPS ayant seulement une interface série.
Garmin
Bonjour !
Télécharger sous Windows 8.1 64bits.
Fonctionne très bien sans supprimer le répertoire BaseCamp. Recherche d'adresse très facile avec cette version.
JMT
JMT
jmt491- 0 sat
Je suis sous vista pack 2 et j'ai la version basecamp 4.2.5
Quand je demande à BC via l'onglet aide/rechercher des mises à jour logicielles il me répond: aucune mise à jour logicielle n'est actuellement disponible
je fais donc comme Sergio la MAJ via le site américain, j'installe et là au lancement de BC j'ai un message "cette application n'a pas pu démarrer car MSVCR90.dll est introuvable. La réinstallation de cette application peut corriger ce problème"
Je retélécharge et je réinstalle et toujours pas de BC
Je pars dimanche et tous mes itinéraire ne sont pas fait et pour ceux qui le sont je ne les avait pas transférés dans le GPS
Une aide ?
Une aide ?
jj.barberousse- 4 sat
Bon résultat des course
je suis allé là: [Vous devez être inscrit et connecté pour voir ce lien] via my garmin j'ai téléchargé la version 4.2.5 proposée et lancé l'installation et là j'ai eu un message qui me disait que l'installation avait échouée
Je suis donc passé par le panneau de configuration du PC j'ai désinstallé BC puis relancé l'installation de 4.2.5 et j'ai tout retrouvé BC et tout mes itinéraires
Si ca peut aider d'autres forumeurs dans le même cas ...
Je viens d'installer cette nouvelle version, pas simplement, j'ai du supprimer l'ancienne, la mise à jour se soldant par un plantage de ce programme.
Et maintenant, la bonne surprise, il semble fonctionner très bien.
La recherche des adresses est même - pour moi - plus efficace, j'ai trouvé deux adresses du premier coup, moi qui n'y arrivais qu'à grand peine avec les anciennes versions... A tel point que j'utilisais Tyre pour me faciliter la tâche.
Bonne journée
Bonne journée
Suite au post de Manuwi j'ai désinstallé la 4.2.5 puis installé la 4.3.1 et toujours le même message "cette application n'a pas pu démarrer car MSVCR90.dll est introuvable" donc redésinstallation de 4.3.1 et réinstallation de la 4.2.5
je réessaye en passant par un arrêt redémarrage PC comme le suggère Sixun
J'ai eu le même problème sur mon ordinateur de bureau puis sur mon portable. Je l'ai résolu en désinstallant la version 4.3.1 via le panneau de configuration de W7 puis en la réinstallant et ça marche...
camper-me- 1 sat
Ca marche merci camper-me
Je récapitule:
Je récapitule:
- Désinstallation version 4.2.5
Installation version 4.3.1 (BC ne fonctionne pas)
Désinstallation version 4.3.1
Installation version 4.3.1 CA MARCHE
Page 1 sur 2 • 1, 2
» Calcul du dénivelé sur une route tracée dans BaseCamp : BaseCamp délire !
» La fin du BaseCamp Cloud et de Google Earth dans BaseCamp le 21 mai 2018
» [résolu] quand je veux telecharger un fichier gpx existant avec basecamp 471 ou 470 , il m'est proposé d'abord la desinstallation de BASECAMP ?
» Basecamp 425 fonctionne mais pas Basecamp 462 une piste ?
» BaseCamp 4.3.1 sur Mac OSX
Page 1 sur 2
